Advice and recommendations
Post  lynnr on Wed 04 Jun 2014, 7:43 am
Can you give me recommendations for a new mechanical lubricator. My current one has completely stopped working. BTW it did work perfectly fine for the last 2 years. I am changing to the Hallett steam oil and it is a lot thicker than the Morrison I was using so think a beefier ratchet oiler will be better anyway.
Also I continue to have problems with the steam valve on the injector so would like to replace that as well. Can someone tell me the size to get and recommendation again please.
Happy steaming
Number of posts : 2919
Re: Advice and recommendations
Post  Kevster on Wed 04 Jun 2014, 9:46 am
hi lynn,
Live Steam Models do a nice ratchet type lubricator I bought one for my engine, looks the part and you can see its working unlike the roller clutch type.
hope that helps
Post  Tim Watson on Wed 04 Jun 2014, 12:40 pm
Try RA Barker (Bruce) for both lubricator and globe valve.
Number of posts : 558
Post  lynnr on Thu 05 Jun 2014, 7:29 pm
Thanks for the recommendations.
Does anyone know the sizes of the injector valve and lubricator nuts please.
I think the oiler is 1/8" but not sure if I am measuring correctly.
Post  the coleman on Thu 05 Jun 2014, 7:54 pm
Hi Lynn
The injector nut is 9/16-26 bsb.And if your talking about the nut right on the end of the lubricator it is 1/4 -40 M.E
Last edited by the coleman on Thu 05 Jun 2014, 7:55 pm; edited 1 time in total (Reason for editing : WORDING)
Number of posts : 212
