Page 13 of 13 Previous  1, 2, 3 ... 11, 12, 13
Post  lynnr on Thu 10 May 2018, 5:58 pm
No other damage done
Number of posts : 2987
Post  lynnr on Thu 10 May 2018, 5:59 pm
I have got the counterweights machined to match the new crank webs. SO tomorrow it should be start to resemble.
Post  lynnr on Fri 11 May 2018, 11:54 am
Well progress is being made. Not  a lot to show for 7 hours of activity over 3 days.
Counterweights now fitted. Machined the gaps a couple thou' under and jacked the weights on using the bolts to get a nice snug fit.
The I needed to fettle the keys for the eccentric cams and they are now fitted. Still need to align them once the crank is in place.
Post  lynnr on Sat 12 May 2018, 12:22 pm
Another day and a bit more done.
Crank main bearings fettled and fitted. I even had to break out the engineering blue.
Missing a picture so will edit later.
Found it
Last edited by lynnr on Sat 12 May 2018, 1:41 pm; edited 1 time in total (Reason for editing : Added picture)
Post  atomenter on Sun 13 May 2018, 8:23 am
Lynn
How come none of your pictures are visible???
Tom
Number of posts : 173
Post  lynnr on Sun 13 May 2018, 8:45 am
Hi Tom.
There all visible to me.
Post  lynnr on Sun 13 May 2018, 11:40 am
This mornings activities
Get the eccentrics squared up with the expansion links and fit the big ends to check alignment and non fouling. Everything is single bolted and just nipped up.
I will need new key steels for the waterpump gear and 3rd gear boss. Due to the original ones being a loose fit on the new crankshaft.
Post  lynnr on Thu 31 May 2018, 11:13 am
Well I do not know how I did it but I forgot to take any more pictures of the crank going back in. Must have been concentrating so much.
Well on to the roof refinishing project. Now that the temperature has got above 5C on a regular basis it is resin time. Hopefully this is the final coat. There is a few little bits of dust in it but I hope it is going to be fine once hardened.
Post  lynnr on Fri 01 Jun 2018, 3:25 pm
Well Crystal is almost fully back together. Couple small jobs to do then it will be first steam of the season.
Post  LiveSteam on Fri 01 Jun 2018, 8:04 pm
Nice job, crumbs first steam of the season Shocked I'm only a week away from our 4th Rally of the season not too mention several local steaming seasons.
Number of posts : 525
Post  Mark the spark on Fri 01 Jun 2018, 9:28 pm
Hi Lynn
Are you going to castle Frazer in a couple of weeks?
Number of posts : 250
Post  lynnr on Fri 01 Jun 2018, 10:00 pm
Hi Mark
Due to finances and health. Both lacking. I have not booked any events this year. I was meant to be at Chipping last weekend but cancelled as the engine was not ready and not much change of me getting her ready in time. So for the time being I am keeping her fully dry and just pottering about with jobs when the body allows.
Post  lynnr on Sat 02 Jun 2018, 4:11 pm
Seat frame serviced and painted.
Universal tow point. Can pull wagons on the normal engine pin or fit the 50mm ball and pin for towing other things.
All towing forces passed straight through to engine taw bracket. So very little strain on the seat or tender edge.
Post  lynnr on Mon 04 Jun 2018, 4:31 pm
Cleaning in progress. Getting there
Post  lynnr on Thu 28 Jun 2018, 1:27 pm
Crystal was out in the sun yesterday. Today was cleanup and maintenance.
Blistering heat
The leftovers from Andy Holmes Welsh Dry steam Coal
Puppy dog found a cool spot.
Post  lynnr on Mon 23 Jul 2018, 2:15 pm
Not been out doing much the last few weeks. Today I decided to make a bracket for the diff-locking drive pins so they can be stored without using up most of the toolbox on the belly tank.
Easy to get to but tucked out the way.
Post  Steve Traill on Mon 23 Jul 2018, 3:34 pm
Good idea, they do take up a lot of space.
Number of posts : 743
Post  lynnr on Wed 10 Oct 2018, 6:06 pm
Sorry for the lack of updates. The health thing getting in the way somewhat.
Managing to potter about with a few little jobs. Thought I would move the second shaft oilers.
Much easier to get to for the injection oiler and removing the lids etc.
Then on to the cannon boxes on the rear axle. Instead of the boxes filling up with water and wasting a lot of oil. I am going with the oil post on the back head with tubes down into the cannon boxes and oil tubes to the axle bearings. Similar to Tim I think. Just waiting for T joints to arrive for final pipe cut and shape. The pots are mounted on my own fabricated brackets.
I will be light steaming the engine in the next 2 weeks for a hot blowdown as it is boiler inspection on the 26th Oct.
