gear cluster uj hub
gear cluster uj hub
Post  Kevster on Tue 18 Mar 2014, 10:55 am
Hi all,
when the 2nd shaft right hand bolt is tightened my gear cluster goes very tight , has anyone else had this problem and how did you fix it please.
Any thoughts welcome
thanks
Re: gear cluster uj hub
Post  lynnr on Tue 18 Mar 2014, 6:10 pm
Check the spacer on the other side as it sounds like your shaft is too far over to the left.
Number of posts : 2981
Post  Kevster on Tue 18 Mar 2014, 6:52 pm
Lynn,
The spacer and gear are not installed the other end, contacted Steve he says to check if the shoulders of the square
all line up , if they dont thats why the hub is being pulled out of true, it may need a bit of machining to square it up
Thanks for your reply though
Post  Tony King on Tue 18 Mar 2014, 7:54 pm
Hi Kev,
I seem to remember doing a fair amount of careful filing & fettling that square on the shaft & the hole it goes into!! having got it working, I found it would only work if assembled in one position, so I dot punched to ensure I always get it in the same place on reassembly!
Post  Kevster on Tue 18 Mar 2014, 8:24 pm
Thanks Tony,
Im going to have a good look at it tomorrow and see how far its out by
Post  highpressure on Tue 18 Mar 2014, 9:51 pm
Also remember if its just tight then it will soon loosen up under running. My whole engine was so stiff I couldnt push it at first as Andys is now but mine now just rolls with no trouble at all. I also remember the shaft only being happy in one orientation.
Post  Kevster on Wed 19 Mar 2014, 6:50 pm
Hi all,
The reason my 2nd shaft  binding after tightening was the shoulders of the square
were not in line , it could have been carefully filed but I set it up on my milling machine
and machined the shoulders true, all spins nicely now , so if anyone has a stiff gear cluster
check your shoulders are all in line .
