cylinder drain pipes
Page 1 of 1 • Share •
Quick question anybody not fitted the pipes please could they messure the longest one as ive used them on something else but forgot to take the size.
the coleman- Number of posts : 212
Re: cylinder drain pipes
400mm is the long one.
IanL- Number of posts : 424
the coleman wrote:ive used them on something else but forgot to take the size.
A Windermere kettle by chance?
bjwlancashire- Number of posts : 934
Thanks Ian and no Brian that uses 3/16 and it's finshed
A proper steam oil feed pipe that doesnt drag over the safety valve!!!
Worth noting that if you are replacing them that Burrells used brass on the cylinder drains. The appropriate size can be sourced from ebay.
Tim Watson- Number of posts : 558
Thanks Tim local model shop stock brass pipe
» Skill Drain
» Cylinder Block Pattern & Cores
» Magic Drain>Infernities?
» Wildheart and Magic Cylinder
» Jinzo/Skill Drain Question
Page 1 of 1
