Gear Change
Gear Change
Post  MrStationHouse on Sat 08 Feb 2014, 2:27 pm
Has any one had any trouble with the second gear mechanism? The second gear is hard into the third gear carrier and you can't move the dog to be able to engage first gear. I could trim the dog, trim the gear arm or put the second gear on the lathe. Thoughts welcome
Number of posts : 313
Re: Gear Change
Post  lynnr on Sat 08 Feb 2014, 3:02 pm
You need to chamfer the inside of the 2nd gear at the splines. It is cut straight and the shaft has a stress release fillet.
that should let the second get in to its correct position.
Number of posts : 2915
Re: Gear Change
Post  MrStationHouse on Sat 08 Feb 2014, 3:06 pm
Cheers. Lynn
I knew someone would have solved it before me.
Re: Gear Change
Post  MrStationHouse on Sun 09 Feb 2014, 8:13 pm
Thanks Lynn, all sorted
Re: Gear Change
Post  lynnr on Sun 09 Feb 2014, 8:33 pm
Excellent.
How posh. Msn with a lathe.
Re: Gear Change
Post  MrStationHouse on Sun 09 Feb 2014, 8:45 pm
Its an old Myford super 7. Really useful to have, but can't profess to be anything other than a novice.
Re: Gear Change
