DCC Showman multi-coloured bulbs
Post  Brian M on Tue 21 Jan 2014, 7:13 pm
I am trying to source a series of different coloured bulbs for the showman canopy. Can anybody point me to a good source?
Thanks in anticipation,
Re: DCC Showman multi-coloured bulbs
Post  eng14110 on Tue 21 Jan 2014, 7:20 pm
Hi Brian,
Have you thought about painting your existing bulbs ? I have done mine with Pebeo vitrea 160 glass paint and the results are very good. You should be able to obtain it from a good craft supplier or purchase from an online supplier
Colin
eng14110
Number of posts : 44
Post  Brian M on Tue 21 Jan 2014, 7:34 pm
Hi Colin,
I never thought of that?
Thanks for the tip, it may even be cheaper than buying them Smile
All the best,
Post  LiveSteam on Fri 24 Jan 2014, 5:58 pm
eng14110 wrote:Hi Brian,
Colin
I'll second that, painting lamps gives very good results, however remember the not to over fire the lamps or you can risk melting the solder connections in the holder, that's if your using screw-in's, otherwise I have painted several hundred lamps like this (or dipped them as it does give a better finish than brush)
Number of posts : 516
Post  Steam Traction World on Sun 26 Jan 2014, 9:03 am
Happy to get quotes for coloured bulbs if enough people want them. I'll probably be able to get them for around a third cheaper than buying them off the shelf in small quantities.
Just let me know what colours and how many you'd want and I'll ask my sources.
Number of posts : 903
Post  Brian M on Sun 26 Jan 2014, 11:59 am
Thanks Dean,
I have already used the paint as suggested by Colin, it looks the dogs &^%^.
ATB,
