wheel bearing
wheel bearing
Post  lintonsteam on Mon 30 Dec 2013, 6:40 pm
Hi i built my front wheels today except in the instruction it indicates there should be wheel bearing which are mentioned in the instruction also have a number included, the number is BU401404 but these are not mentioned in the delivery manifest a.ny body able to comment on this
lintonsteam
Number of posts : 31
Registration date : 2013-10-07
RE wheel bearing
Post  AndrewR on Thu 02 Jan 2014, 2:35 pm
STW stopped using bearings on the front wheels with the last batch of agriculturals. (Some got them and some didn't) Apparently the new metal they are using for the front axel doesn't need bearings (some special type of graphite steel from memory). If the inside diameter of the hubs and the diameter of the axel shaft are the same then you don't need to worry about it.
I'm sure Steve will get around to updating the docs one day.
Cheers Andrew
AndrewR
Number of posts : 18
Re: wheel bearing
Post  lintonsteam on Thu 02 Jan 2014, 6:47 pm
hi thanks for that  Smile  feel lot better for that
lintonsteam
Re: wheel bearing
Post  Mat + Lindy on Sat 04 Jan 2014, 3:05 pm
Hi all,
Hope you are all well..
FYI We didn't get any wheel bearings with our kit 1 either, we had a heart attack when we watched CriX's video on youtube and saw his hub was different to ours.
Thankfully we're not alone...
Good luck everyone!
Mat + Belinda
Mat + Lindy
Number of posts : 1
Registration date : 2014-01-04
Re: wheel bearing
