Foden rear brake
Foden rear brake
Post  Hecter on Mon 07 Oct 2013, 8:27 pm
Does the break pad need to be glued to the band? we drilled the holes using clamps and i think that it will just make a lot of mess and make it more annoying when it comes to changing the material over if you ever needed to.
Hecter
Number of posts : 50
Registration date : 2013-02-13
Re: Foden rear brake
Post  FodenSWB on Fri 25 Oct 2013, 3:00 pm
Hi, we bonded ours as it said to in the instructions I think we used evostik from memory
FodenSWB
Number of posts : 27
Registration date : 2012-08-31
Post  mikero on Fri 25 Oct 2013, 3:21 pm
I glued mine. I think the material around the bolts would begin to tear after a while without the glue to stop it moving, its got about half a ton of force going into it, like trying to stop a car with one pair of brake pads.
Number of posts : 257
Post  atomenter on Fri 25 Oct 2013, 8:12 pm
I "glued and screwed" mine and after 2 seasons rallying there hasn't been a problem. I also fitted a "return" spring to the brake band to help it to release.
Tom
Number of posts : 173
Post  mikero on Fri 25 Oct 2013, 8:24 pm
That's a good idea Tom, any chance of a picture of how you did it?
Post  atomenter on Fri 25 Oct 2013, 10:12 pm
Hi Mike
Will take one tomorrow if I get a chance.
Tom A
Post  atomenter on Sat 26 Oct 2013, 11:19 pm
Hi Mike
As promised a pic of the brake return spring.  I just tied the actuating lever back to underneath the towbar.
Hope this helps.
Tom A
Post  mikero on Sun 27 Oct 2013, 12:28 am
Thanks Tom, I will have a sort through my spring drawer for something suitable.
Post  hartshaulage on Mon 06 Apr 2015, 6:08 pm
Can any one show me a picture of how the break rod is fitted to the rear and break leaver, as im worried when mine arrives its going to hit the water tank gauge
thanks russ
hartshaulage
hartshaulage
Number of posts : 231
Post  phil gomez on Wed 08 Apr 2015, 6:24 pm
Hi Russ.
Did you have any luck with getting hold of any pictures the rear brake assembly.
Phil.
phil gomez
Post  hartshaulage on Wed 08 Apr 2015, 6:42 pm
No mate still waiting, ive had another look at mine and im still sure that it will hit
Russ
hartshaulage
hartshaulage
