Regulator Quadrant
Regulator Quadrant
Post  AndrewR on Fri 16 Aug 2013, 5:53 pm
Does anyone have a picture of the regulator quadrant with the slots for the reversing lever cut?
With the latest batch of engines they have left it for the builder to cut them rather than building an adjustment mechanism into the rod. The pictures in the instructions show 3 forward. 3 reverse and 1 middle slot - however - in full reverse my lever only goes back to just past half way, ie no where near enough room to cut all those slots Shocked
Any pictures, help much appreciated.
Cheers Andrew
AndrewR
Number of posts : 18
Re: Regulator Quadrant
Post  lynnr on Fri 16 Aug 2013, 9:19 pm
My picture thread shows the quadrant. For reverse you only need 1 slot. Full. As you are not often sitting in reverse.
Number of posts : 2940
Post  Tony King on Sat 17 Aug 2013, 8:20 am
Hi Andrew,
As Lynn points out, you don't really need three slots for reverse, however, I've done two on mine, so I can notch it back a bit to save on steam!!
Here's a pic showing my quadrants & as you have observed the notches are near the front, but you will also observe the reversing lever is to the rear of all the notches, so needs the "extended" quadrant to slide in!! :-
Hope this helps,
Reply with quote Re: Regulator Quadrant
Post  AndrewR on Sat 17 Aug 2013, 9:54 am
Many thanks, will go ahead and cut the slots today.
AndrewR
Post  bjwlancashire on Thu 22 Aug 2013, 12:19 am
Andrew
I would suggest not cutting the slots until you are in steam as the furthest position cannot be to far forward or back as the valve gear can be overstressed if it is set to far forward or backwards. the easiest way is to run the engine without the slots but slide in a small flat screwdriver at the end of the travel and slide it up and down as the engine runs to find the point just before the valve gear starts to make the reversing lever jump. If you had the slot filed here then locking the reversing lever by the slot in this position will mean the valve gear components will try to bend/break. You will see what I mean during holding it by hand.
There is a post possibly on the DCC Road Loco thread about this, I think HIGHRESSURE put it on after he had gained advice from Julia on here about this.
Post  highpressure on Thu 22 Aug 2013, 5:38 pm
Yes totally agree with Brian here, I have already replaced my die blocks as I set the lever furthest forward and stressed it all out and pulled it too much. I have since taken the quadrant off, welded the old slots up and recut them in situ. As Brian says best done in steam and then mark the slots and take off to cut.
