Flapwheel grit
Flapwheel grit
Post  Tempopete on Wed 31 Jul 2013, 3:12 pm
I have seen the good old flapwheel mentioned in regard to finishing kit parts. What grade grit wheel would be recommended please?
Peter
Tempopete
Number of posts : 7
Registration date : 2013-06-15
Re: Flapwheel grit
Post  lynnr on Wed 31 Jul 2013, 3:33 pm
I have used 40 and 80 flap wheels, barrel sanders and disks.
Number of posts : 2976
Flapwheel grit
Post  Tempopete on Wed 31 Jul 2013, 4:09 pm
Many thanks for that....off to the shops right now....must be prepared and October's getting closer.
Tempopete
Number of posts : 7
Re: Flapwheel grit
Post  IanL on Thu 01 Aug 2013, 11:13 am
I have used flap wheels in the electric drill very useful even more so when they have worn down a bit as they get into smaller spaces. Flap discs in the angle grinder 80 grit, fantastic way to profile the edges of spokes and other parts, but caution as they can quickly remove too much material. For removing the laser scale on the spokes I found the scotch brite discs in the angle grinder were the best again 80 to 160 grit. They do tend to wear down fairly quickly but save a huge amount of elbow grease! I found the flap wheels did nothing to remove the laser scale.
Happy building
Flapwheel grit
Post  Tempopete on Thu 01 Aug 2013, 11:51 am
More good advice , many thanks. All I need now is a kit.
Tempopete
Number of posts : 7
Re: Flapwheel grit
