Kit 8 - Steering Wheel Shaft Missing Fixing Hole
Post  FodenSWB on Tue 25 Jun 2013, 7:33 pm
Not sure if it is just ours but for information the M4 tapped hole was missing in the Steering wheel shaft for the penny washer fixing.  We have sorted it by sticking it in the Myford to drill the hole then tapped it M4.
FodenSWB
Number of posts : 27
Registration date : 2012-08-31
Re: Kit 8 - Steering Wheel Shaft Missing Fixing Hole
Post  Hecter on Wed 24 Jul 2013, 8:05 pm
We had the same problem but decided on going with an m6 hole for a bit more security. Did you by any chance have any problems with thepart of the brake that clamps around the axle not clamping tight?
Hecter
Number of posts : 50
Registration date : 2013-02-13
Post  FodenSWB on Thu 25 Jul 2013, 7:23 am
We had a little clearance on the brake to axle casting but not excessive so we just used a small amount of bearing retainer when assembling and that did the trick.
FodenSWB
