Showman Lights
Page 1 of 1 • Share •
Showman Lights
Hello All,
I have just soldiered all the lights around the canopy. Once connected to a battery charger through the connector block the lights do not light up??????
Connecting the charger to one light it lights up nicely, but on the loop I get no activity. Has anybody else experienced this problem, if so what was the resolution?
Thanks,
Thanks,
Brian M- Number of posts : 261
Re: Showman Lights
Brian,
The current drain of all the lights may be too much for the battery charger, as chargers normally only have a very low current to avoid damaging the battery when charging.
I would try a car battery to give enough power to drive all the lights.
IanL- Number of posts : 424
Re: Showman Lights
Did you scrape the insulation coating off the copper wire before you soldered the light wires to it? If you didn't, the lights won't work!!
I know because, I didn't!!!
Tony King- Number of posts : 856
Re: Showman Lights
Thanks for the response chaps!
NO I did not remove the installation cover off, as it did not mention it is the instructions
It makes sense know you mention it - Thanks!
Re: Showman Lights
I believe it s in the instructions. Yes you need clean copper to solder to. Some lacquer will decompose to a sort of flux if made hot enough.
You will also need a psu that can give 12v at 27 amps to get full brightness.
lynnr- Number of posts : 2919
» Lynn Robinson. Showman Scenic
» deville tail lights with buckets for custom install $100
» LED Tail lights
» Listed my t-84 lights
» Tinted Tail lights?
» LED Tail lights
Page 1 of 1
