Foden brakes
Foden brakes
Post  hippy dave on Fri 29 Mar 2013, 7:10 pm
Hi has anyone had to file,sand brake shoes on to get wheels on cheers Smile
hippy dave
hippy dave
Number of posts : 188
Re: Foden brakes
Post  burrell1 on Sat 30 Mar 2013, 9:25 am
I also found that I had to remove some of the brake friction material in order to get the wheels to fit. Once I had established what was needed it was quite a simple task. I used a flap wheel on an angle grinder to do the job. All that is required is to identify and remove the high spots. I think the high spots have been caused by the thickness of the glue used to attach the friction material to the brake shoe. I would recommend that you wear a face mask because of the very fine dust and a thick pair of gloves due to the fine wire in the friction material. Best of luck but if it helps I did find doing the second pair of shoes much quicker.
Bill
burrell1
Number of posts : 156
Re: Foden brakes
Post  Adam Brown on Thu 11 Apr 2013, 2:47 pm
Yes, currently going through the process now. Not a very enjoyable job
Adam Brown
Number of posts : 63
Re: Foden brakes
