From 4 1/2 inch to 6 inch
Post  Peppe on Fri 01 Mar 2013, 12:53 pm
After a some what start stop build of the 4 ½ inch Foden , it has been an absolute joy to play with over the last year. I had to convince my self I need a 6 inch, Foden that is, and received several kits in one go. Very Happy
The build so far has gone smoothly and the only the only real problems are the ones I have created myself. Comparing the size of the 4 ½ inch to the 6 inch, Foden that is, I am going to need a bigger “boat”.
I have incorporated the oil modification to the diff and it has worked out well, but don’t look to close to the welding.
I am not to sure about the paint scheme but the chassis is alpha red and the cab I will probably do in Nettuno Blue. On this build I am also going to have it sign written as the build progresses.
The only thing that I can have a moan about is that Steve and the production team should produce the kits FASTER
Keep banging those rocks together!
Peppe
Peppe
Number of posts : 2
