Tyre pressures
Tyre pressures
Post  Mike on Fri 04 Jan 2013, 2:10 pm
What is the correct tyre pressures for the Lykamobile?
On the tyre is the maximum 42 PSI Cold.
Too hard will give a hard ride, too soft and you lose grip.
Does any one know what the correct working PSI should be?
Number of posts : 22
Registration date : 2011-09-13
View user profile http://new email  mike.tuck27@gmail.com
Re: Tyre pressures
Post  augustrock on Sat 05 Jan 2013, 4:09 pm
Not a clue to the correct pressures but I have settled for 30psi front and 35psi rear. These seem a fair compromise over our very rough local roads.
I have now covered over a thousand miles and the tyres have given no problems.
Peter.
augustrock
Number of posts : 29
Re: Tyre pressures
Post  ejparrott on Mon 07 Jan 2013, 9:19 am
There is a method for normal car tyres but I don't know how the Lika's tyres compare.
Draw a chalk line across the tyre, roll it across a flat surface. the chalk should be rubber off across 75% of the width if the tyre pressure is correct.
ejparrott
Number of posts : 117
Re: Tyre pressures
Post  Robfishman on Mon 07 Jan 2013, 11:30 pm
Interesting, is that with the tyre not under load?
Re: Tyre pressures
Post  ejparrott on Tue 08 Jan 2013, 7:25 am
Loaded, at least, I've always done it loaded!
ejparrott
Re: Tyre pressures
