Exciter Dynamos
Exciter Dynamos
Post  Steam Traction World on Fri 07 Dec 2012, 9:43 am
I've copied below a letter that will be going out to all Showmans customers.
We are just about to place our order for the main dynamos. As youíre no doubt aware we are supplying the main dynamo as part of the kit structure. This dynamo will have the capacity to run all the canopy lights (all 64 of them!) but precious little else.
We have designed the exciter dynamo casting so they will if desired take an additional dynamo. This additional dynamo is not included in the kit price.
The reason for this letter is to ask you to let us know if you will require an additional dynamo. We can then pass on to you any discount we can get due to the size of order. The dynamos can be ordered individually at a later date but they will be significantly more expensive.
The dynamos are actually a DC motor initially intended for mobility scooters. We mechanically modify them so they have both an input and output shaft. We canít give you an exact price yet because this will depend on the number ordered. I would however expect it to be around £100.
Please phone Isabel as soon as possible with your decision. You must do this by December 18th 2012 at the latest to take advantage of this offer.
Number of posts : 907
Re: Exciter Dynamos
Post  lynnr on Fri 07 Dec 2012, 9:54 am
My name is on the list.
Number of posts : 2969
Re: Exciter Dynamos
Post  Robfishman on Sat 08 Dec 2012, 9:17 pm
Thanks Dean
Ill give Isabel a call, do you know what the output will be?
edit....just got home and letter on the mat.
Re: Exciter Dynamos
