wooden boiler lagging
Post  Kevster on Sat 17 Nov 2012, 5:41 pm
Hi all,
Those that have lagged their boilers the traditional way what thickness of wood did you use please?
Re: wooden boiler lagging
Post  eng14110 on Sat 17 Nov 2012, 6:02 pm
Hi Kev,
I have used 9mm square tulipwood strips on my showmans it seemed to be about the same as the ring provided
hope this helps
Colin
eng14110
Number of posts : 44
Post  Kevster on Mon 19 Nov 2012, 5:38 pm
Hi Colin,
Thanks for the info
Can I ask where you got yours from please?
Would ordinary softwood be ok to use ,was thinking of painting it with something to help preserve it.
Post  eng14110 on Mon 19 Nov 2012, 7:11 pm
Hi Kev,
I had some problem tracking down tulipwood at a fair price.I mentioned it to a couple of guys at dorset and a friend of Tim Watson
picked some up for me and dropped it off at old warden for me.I believe it was offcuts from a stockist in Worthing,Tim may be able to help.
I was advised to use Tulipwood as other woods may give off a resin that will eat into the boiler. I don't know if there is any truth in that but was not going to take a chance.
Colin
eng14110
Post  Kevster on Mon 19 Nov 2012, 7:40 pm
Thanks Colin,
I will have a look around the internet see whats about.
Wood lagging
Post  Steve Traill on Mon 19 Nov 2012, 7:43 pm
Tulip wood & Poplar are used for lagging, they are very dry (little resin) and offer slightly more resistance to burning than other woods. On full size engines they are usually spaced off the boiler with some sort of strips. This provides more insulation and stops the wood getting quite so hot. On a miniature this is tricky! also it would pay to keep the wood strips back say 1/2" from the smokebox which can get very hot & if it is going to burn it will burn from that end first.
Number of posts : 700
Post  Kevster on Mon 19 Nov 2012, 8:30 pm
Thanks for the info Steve,
keeping it slightly of the boiler and back from the smokebox sounds a good idea.
