New Build Burrell
New Build Burrell
Post  simonbos on Thu 08 Nov 2012, 1:19 pm
Received my first three kits for 4" Ag. Burrell yesterday.
First question of many I expect - what is the best way of degreasing the tender metalwork? as they are very oily.
Thanks,
simonbos
Number of posts: 19
Registration date: 2012-09-20
Re: New Build Burrell
Post  lynnr on Thu 08 Nov 2012, 1:21 pm
Paint Prep - Panel pre-wipe works well.
Soap suds and elbow grease also works.
Number of posts: 1688
Registration date: 2010-08-06
Post  IanL on Thu 08 Nov 2012, 3:13 pm
I used Gunk painted it on left it to drain then washed using a hosepipe need to dry it well or it will rust pretty quickly. Normally used to degrease car engines etc.
Number of posts: 244
Registration date: 2011-07-25
Post  hudmut on Thu 08 Nov 2012, 3:33 pm
I hit all fresh steel with standard thinners then 80 grift with a DA sander to key the steel then a good wipe down with the thinners once more before paint. Cellulose thinners has a lot more bit and so is good for getting that dirt of first time round dont use it once there is paint on there as you will wipeing that off to use per-wipe after you have paint on the job and don't forget to wipe it on with one clothe and of with another
One good tip to is don't use paper towels or rags there full of dust that won't show until you paint get a box of proper body shop wipes tack rags are to pick bits up not remove every thing that is left from your prep work small costs now are nothing over the time in takes to sort out up setting paint work.
Let me know when you are board of sanding round rivets I have a trick for that to.
Mates in body shops are useful to
hudmut
Number of posts: 67
Registration date: 2010-07-05
Post  MrStationHouse on Thu 08 Nov 2012, 4:53 pm
I always use panel wipe
Number of posts: 125
Registration date: 2011-04-26
Post  Robfishman on Thu 08 Nov 2012, 6:01 pm
I use Swarfega Jizer Degreaser, comes in a 5litre tin for about £20. This is an emulsifiable degreaser, widely used in industry and the automotive trade. It will not stain or damage most plastics, synthetic rubbers or paints and it rinses off with water. One I use also has a rust inhibitor built in (if that’s the right term). Also seems to remove any loose scale with ease.
I find it works great. I transfer to a small spray bottle, spray the parts and give them the once over with an old paint brush before running under cold water. Works a treat and lad lasted me ages as you dont use much.
edit...only £15+ P&P here...... http://www.powertoolsdirect.com/swarfega-jizer-degreasers-range?utm_source=google&utm_medium=merchant I'm sure your good local car centre will stock it, (Not Halfords, if they stock it you'll probably pay more than you need to). Get mine from Camberly Auto Factors who have a place not far from me.
Number of posts: 681
Registration date: 2010-11-26
Post  Robfishman on Thu 08 Nov 2012, 6:15 pm
hudmut wrote: Let me know when you are board of sanding round rivets I have a trick for that to.
My trick.......get someone else with small fingers to do it for me, if all else fails use a fibreglass pencil (i think thats what it is anyway)
Post  hudmut on Thu 08 Nov 2012, 6:31 pm
You got it them fibreglass brushes are a god send.
hudmut
Number of posts: 67
