Making a Start
Making a Start
Post  Chris.C on Wed 10 Oct 2012, 7:16 pm
Hello everyone!
Just want to say hi and give a little intro. After spending every summer from the age of 4 to 14 watching my grandfather (Dennis Weeks) build a 4Ē Burrell, Foster and Portable from scratch I became fixated with Steam Models anything any size! I attended every steam rally I could. Unfortunately he passed away and the family didnít feel the engines were for them due to no experience running and maintaining them so they were all sold off (to my disappointment, as I had imagined running them all Very Happy ). I spent the next 12 years pondering what could be done.
However I am now 26 and have the spare time to build one from the kits that STW supply. With a limited knowledge of engineering STW kits are a gift from the powers above for myself and others like me. Iím now waiting for the first kit to arrive and look forward to the cuts and bruises I will be getting.
I have seen so many beautiful engines on this forum and I look forward to adding my engine to the ever growing gallery. Very Happy
Chris
Chris.C
Number of posts : 11
Registration date : 2012-10-10
Re: Making a Start
Post  lynnr on Wed 10 Oct 2012, 7:29 pm
Welcome aboard Chris.
Yes you will get cuts etc. also say goodbye to your nails.
Number of posts : 2908
Re: Making a Start
Post  Chris.C on Wed 10 Oct 2012, 8:21 pm
Thanks Lynn. seen some brilliant pics of your showmans engine.
Chris
Chris.C
Re: Making a Start
Post  Tim Watson on Wed 10 Oct 2012, 9:33 pm
Chris:
You'll have great fun. I have.
Number of posts : 558
Welcome to the Club
Post  Steve Traill on Wed 10 Oct 2012, 11:24 pm
Having built three of these engines they are a well sorted, powerfull engine. Enjoy the build, take your time with each kit and the finished result will give pleasure for many years. cheers cheers cheers
Number of posts : 694
Re: Making a Start
Post  Robfishman on Thu 11 Oct 2012, 12:00 am
Yes good luck Chris, will be good to see another build underway.
Re: Making a Start
Post  Frostie on Fri 12 Oct 2012, 7:20 am
Welcome to the forum Chris, weekends and spare time will never be the same !!!
Enjoy the build, the last few bits, and the first steaming give an enormous sense of pride and achievment.
Good luck mate.
Mal
Frostie
Number of posts : 145
Re: Making a Start
Post  Chris.C on Fri 12 Oct 2012, 3:55 pm
Thanks for the welcome people! Very Happy I'm sure I will be picking your brains at some point!
Chris.C
Re: Making a Start
Post  Chris.C on Mon 15 Oct 2012, 1:02 am
Hi all,
couple of questions for all of you, any help would be appreciated.
Q1. How did you go about preparing your metals for primer and undercoat?
Q2 What paint did you use for the boiler and hornplates?
Q3 would it be easier to get it sand blasted? if so what would be the rough cost?
Thanks in advance
Chris
Chris.C
Preparing the metal
Post  Steve Traill on Mon 15 Oct 2012, 10:06 am
Hi Chris
What I use for preparing the metal are various flap wheels and a 4" grinder. Use the grinder for taking the sharp edges off and then a flap wheel in a drill to smooth it all off. To get the millscale off there are various wheels that fit a small grinder but they are all quite expensive and I've found they don't last very long. The best thing I've found is a rubber wheel with tungsten teeth in it. It fits in a drill and at a slow speed takes the millscale off easily. I picked it up at Dorset this year in the NTET tent. It leaves a sort of shot blasted finish which gives the paint plenty to grip to.
I recommend the Craftmaster paints, the enamel range have all the traditional engine colours and it gives a really hard finish. For brushing use straight out of the tin or for spraying thin by about 5% depending on the temperature you're spraying in.
Sand blasting is good for a paint finish and if you have someone nearby then I would use them, one word of warning though some industrial sandblasters can leave a really rough finish that is hard to get smooth again. Check the finish before handing over any parts! Costs vary depending on how busy they are so shop around.
Re: Making a Start
Post  Chris.C on Thu 18 Oct 2012, 10:22 pm
Thanks for the info Steve this has helped. Very Happy
Chris.C
Re: Making a Start
Post  Chris.C on Sun 21 Oct 2012, 3:17 pm
Is it best to use heat proof paint for the boiler?
What about the hornplates? (Standard enamel?)
Chris.C
Re: Making a Start
Post  Chris.C on Tue 23 Oct 2012, 3:32 pm
1st Kit arrived today! Time to get dirty Very Happy
Chris.C
Re: Making a Start
Post  lynnr on Tue 23 Oct 2012, 4:03 pm
Congratulation on first kit.
On the boiler I used stove heat resistant paint as it only needs 200 degC couple coats and I also done a heavy coat of zinc primer on top. The sides of the boiler I kept to 1 coat of heat resistant 500degC and quite thin. This area is well covered so should not take impact and you want think where the hornplates touch so that the paint does not thin out and loosen the horn plates.
On my horn plates I have used standard paints. In my case 2pak imron coach paint as the hornplates should not get overly hot.
Re: Making a Start
Post  AndrewR on Tue 23 Oct 2012, 4:48 pm
[quote="Chris.C"]1st Kit arrived today! Time to get dirty Very Happy
Oh, you're just gonna love that isoflex.....
AndrewR
Number of posts : 18
Finally Xmas is over!
Post  Chris.C on Wed 16 Jan 2013, 7:54 pm
Finally the Xmas period has ended, managed to kindly convince my mum to build a large garage/shed in the garden before Xmas and to my surprise its nearly finished. She is as excited about this project as i am.
2nd kit came before Xmas as soon as the electrics are installed i will be posting build photos and plan to keep my own little build diary.
One problem i have encountered is that the clue to hold the rubber Tyre together has come loose and i know have one round Tyre and one long piece of rubber! any info on what i can use to re glue it?
Chris.C
Re: Making a Start
Post  lynnr on Wed 16 Jan 2013, 7:58 pm
I think simple superglue is used, but check with Steve. He may suggest sending back.
Re: Making a Start
Post  Richard on Wed 16 Jan 2013, 11:37 pm
yes super glue get a good one
Richard
Number of posts : 98
Re: Making a Start
Post  Chris.C on Thu 17 Jan 2013, 6:49 pm
Thank you, wanted to double check before i get covered in it Very Happy
Chris.C
3rd Kit
Post  Chris.C on Sun 10 Mar 2013, 3:05 pm
3rd Kit arrived last week, Garage/Large Shed will be finished in the next week so i can get started Smile Missus wont be happy im going to be coming home covered in ISOFLEX! Twisted Evil
Been trying to find Julia Olds build diary but the links provided are not working, can anyone provide info?
Chris.C
Re: Making a Start
Post  lynnr on Sun 10 Mar 2013, 3:19 pm
Traction talk has a working link or I think one of the steam suppliers do possibly berrybrook?
Burrell Builders Diary by Julia Old
Post  simonbos on Sun 10 Mar 2013, 3:36 pm
Chris
Got my copy of Julia Old's Burrell Builders Diary from MJ Engineering Tel. 01252 890777
The Forge, Cricket Hill Lane, Yateley, Hampshire GU46 6BB
About £29 if I remember correctly but well worth a read - has helped me a lot so far with my build
simonbos
Number of posts : 57
Re: Making a Start
Post  bjwlancashire on Thu 14 Mar 2013, 5:44 am
Here you go Chris
If you are a memeber of Traction Talk you should be able to follow this link. There is a picture in the middle of the page, you just click on it and it asks you if you want to save the file or open it.
http://www.tractiontalkforum.com/showthread.php?t=11246
Re: Making a Start
