smokebox paint
smokebox paint
Post  tractor mike on Thu 20 Sep 2012, 6:14 pm
hi everybody can somebody advise on where would the best place to get heat proof paint for the smoke box and chimley from please
tractor mike
Number of posts : 74
Re: smokebox paint
Post  lynnr on Thu 20 Sep 2012, 6:33 pm
I use B&Q Pastikot satin stove paint. Appears to work quite well.
Number of posts : 2987
smokebox paint
Post  tractor mike on Thu 20 Sep 2012, 6:35 pm
ok lynn thats great, well done on the engine it looks good
tractor mike
Re: smokebox paint
Post  mikero on Thu 20 Sep 2012, 11:56 pm
I used satin barbeque paint, never had any problems.
mike
Number of posts : 257
Re: smokebox paint
Post  Robfishman on Fri 21 Sep 2012, 7:49 am
I used the satin black VHT paint from Frost.
Re: smokebox paint
Post  Tim Watson on Fri 21 Sep 2012, 11:22 am
Smooth Hammerite on bright metal: worked well on an engine that has done some pretty hard work.
However, all paint will burn / flake off if the chimney gets very hot. On my engine, the metal has become blued with the heat transfer. I think it is important to keep the paint oiled ahead of very hard work to keep it flexible so that it can shrink back to the metal on cooling.
Re: smokebox paint
Post  Frostie on Sat 22 Sep 2012, 4:30 pm
Plasticote Bar-B-Que paint (Satin) from Do It all
First class stuff.
Mal
Frostie
Number of posts : 145
Re: smokebox paint
Post  busman on Sat 22 Sep 2012, 7:58 pm
Plasticot also do satin black woodstove paintfound this in the "Range" shop.
busman
Re: smokebox paint
Post  Tufty on Wed 18 Feb 2015, 10:12 pm
to all the plasti cote users I read on the back of the bbq paint can that it has to be 'cured' within 8 hours of painting. Did you and how?
Tufty
Number of posts : 17
Registration date : 2012-02-28
Re: smokebox paint
Post  lynnr on Wed 18 Feb 2015, 10:23 pm
I put my smokebox in the oven for a couple hours.
Re: smokebox paint
Post  Tufty on Wed 18 Feb 2015, 10:31 pm
I was worried that was going to be the general answer, mine isn't a new build so the smokebox is on the boiler, also not sure if the chimney would go in anyway...
Tufty
Re: smokebox paint
Post  lynnr on Wed 18 Feb 2015, 10:37 pm
Set a fire in the smokebox and cook from the inside?
Re: smokebox paint
Post  Tufty on Wed 18 Feb 2015, 10:45 pm
I did wonder about putting the chimney and base back on the smokebox and using a propane burner aimed inside but not sure if
a) the heat would be too 'localised' and the paint ending up in patches of different colours/shades.
B) the boiler would be damaged as there is no water in it (the engine is fully stripped for painting and is currently a boiler with smokebox and cylinder block) pale
Tufty
Re: smokebox paint
Post  Kevster on Thu 19 Feb 2015, 7:01 am
Just spray it dont touch for at least week or longer if you can, works for me.
Re: smokebox paint
Post  Tufty on Thu 19 Feb 2015, 9:24 am
Kevster wrote:Just spray it  dont touch for at least week or longer if you can, works for me.
Nice one, cheers
Tufty
Re: smokebox paint
