Foden Gears
Foden Gears
Post  Steam Traction World on Wed 21 Jan 2009, 5:29 pm
Dear Foden Builders,
We are pleased to inform you that we have received a large delivery of gears today (photo below). This means that we shall be in the position to despatch the following items shortly:
F41230 Dart Bar Bracket x2
F41830 Reach Rod x1
F41835 Flywheel Key x1
F42001 Gear Mounting Spindle x1
F42003 2nd shaft Key x1
F42004 Fast Pinion Gear x1
F42005 Pinion Gear 1 & 2 x1
F42006 2nd Shaft x1
F42014 Retaining Block x1
F42021 13T Sprocket x1
F42105 Gear Change Fork x2
F42107Gear Selector Guide x4
F42322 Front Bracket LH x1
F42322M Front Bracket RH x1
F42323 Front Support x2
F42324 Mid Support x2
F42325 Mid Bracket LH x1
F42325M Mid Bracket RH x1
F42390 Lubricator Bracket LH x1
F42390M Lubricator Bracket RH x1
Engine to Ajuster Chain
Adjuster to Diff Chain
Chain Joiner x2
SF00203 Lubricator Kit x2
Face Seal x1
'O' Ring x1
Injector
Additional to these items 9 lucky customers will also recieve the items below:
F42010 118T Gear x1
F42011 102T Gear x1
F42012 88T Gear x1
F42017 Chain Sprocket x1
These customers will be chosen on the following criteria; How close they are to completing their engines? Whether or not they have recieved a boiler and a cylinder block? and how nice they have been to us since we started! Very Happy If you have received your boiler and cylinder block and would like adding to the shortlist then please get in touch as soon as possible. Do not worry if you do not receive these four gears initially as the balance have been completed and delivery is currently being organised. Once these have been delivered it should only leave the steam fittings, water pump drive and a couple of other items till completion.
Dean & Steve
Number of posts : 913
Great New!
Post  Julia on Wed 21 Jan 2009, 6:13 pm
This is very encouraging news - well done.
I can't find F41230 Dart bar Bracket x2 on the list of outstanding parts.
Is guess this goes in the smokebox. It this a replacement or something that is currently missing?
Julia
Number of posts : 71
Foden Gears
Post  greystones on Wed 21 Jan 2009, 8:39 pm
Hi Steve / Dean, What a wonderfull company you run, so efficent and professional even down to the dog. Yes I can creep as well as the next man. Would you be good enough to put my name down for a set of gears. Cheers Mike
greystones
Number of posts : 65
Re: Foden Gears
