BU41133 Regulator spring
Post  Tassie Tiger on Mon 03 Sep 2012, 2:09 am
Need some help with this one. the BU 41133 Reg spring does not get a mention in the instructions. Does it locate in behind the reg nut BU41118 in the hole or is it not needed?
Phil
Tassie Tiger
Number of posts : 47
Regulater spring
Post  Steve Traill on Mon 03 Sep 2012, 10:17 am
The regulater spring locates in the little hole in the block that is grubscrewed onto the regulater rod. It is there to provide a little downward pressure until the steam pressure takes over. You will find that it slides really easily with no pressure but as you steam up & the pressure in the boiler increases the regulater becomes quite stiff due to the downward pressure from the steam.
Number of posts : 714
regulator spring
Post  Tassie Tiger on Mon 03 Sep 2012, 11:24 pm
Thank's Steve for your help.Phil
Tassie Tiger
Re: BU41133 Regulator spring
