Water tank size
Water tank size
Post  jjtjr on Fri 10 Aug 2012, 12:22 pm
After some though I started to make a front tank. The tank is 9"O.D. in diameter
and will be from 30" to 32" long and will be mounted in front of the front leaf
spring.Below the dash panel. The tank will have a capacity of 8.33 gals. The car
will have a total water capacity of 12 gals + 8.33gals = to 20.33 gals. This
number is more inline with the original Locomobile. The tank is made from rolled
copper sheet because it is hard to find 8" copper pipe. At this time the copper
cylinder is made and the end caps will be made by spinning of the copper to form
a concave disc.The tank will be silver solder together. The tank will have a
filler on top with a pickup tube on bottom. The tank will be plumbed with a shut
off valve and check valve to prevent any cross flow from the other tanks. All
three tanks will feed the boiler pump.It would be nice to made the tanks from
brass but that is even harder to find, The copper will look good when its
polished.
jjtjr
jjtjr
Number of posts : 117
water tank
Post  jjtjr on Tue 15 Jul 2014, 11:43 am
Tank was built using copper sheet. The end caps were press from the same copper sheet. The tank holds 8.2 gals of water. It is plumbed to the main tanks and could be shut off from them.
jjtjr
jjtjr
Your Canopy!
Post  Goliewogs on Tue 14 Jun 2016, 3:55 pm
Please could you tell me where you obtained your beautiful folding canopy from for your Lykamobile? I am just about to start building my Lycamobile (series 2) and would like one of these!!!
Goliewogs
(Greg Powell)
Goliewogs
Number of posts : 46
Re: Water tank size
Post  jjtjr on Tue 14 Jun 2016, 7:21 pm
Where are you located I am selling the top if interested let me know
jjtjr
jjtjr
Your Canopy!
Post  Goliewogs on Wed 15 Jun 2016, 8:13 am
Many thanks for your quick reply! Yes, I am interested in it, but of course depends on cost and also shipping costs!. I think you are in the US so it shouldn't be too bad for shipping. I am in Northern France - so not too far away!
Contact me direct by email on gregory.powell@wanadoo.fr as its probably more convenient.
Rgds
Greg
Goliewogs
Re: Water tank size
