Experimental steam up
Post  lynnr on Wed 01 Aug 2012, 8:57 pm
At the next test steaming. I am going to try using the compressed fire logs to see how they perform. 40% higher calorific value and at less then 10% moisture. Should reduce the startup condensation and provide improved start heating.
It may work or Crystal may just caugh them up and not like the taste.
Number of posts : 2940
Re: Experimental steam up
Post  highpressure on Thu 16 Aug 2012, 7:55 am
Hey Lynn,
You seem to have been very quiet for a while, whats going on with you and the build? How's the steamings coming on?? Have you ran it much yet?
Cheers Kev.
Post  lynnr on Thu 16 Aug 2012, 10:00 am
Hi Kevin
Not been able to do much at the moment. Ministering to parents and doing a lot of jobs that father should have done. Both have been quite ill recently. Mother had phemonia.
I hope to be able to test steam on Monday.
