Heat Resistant Etch Primer
Post  bjwlancashire on Thu 21 Jun 2012, 8:55 pm
Question for Adam or anyone else that knows.
I want to paint my safety valve chimney black using the satin black engine paint I used on the cylinder block. It sticks like s%@+ to a blanket on the cast iron but it is not great on the simpling valve pipe etc.. Is there a primer that will take the heat and still allow me to paint on top of it with the Halfords engine paint?
I refuse to polish this part, Blackbeard is the name.
Re: Heat Resistant Etch Primer
Post  sonick45 on Thu 21 Jun 2012, 9:54 pm
try this.
Metcote
NS5 ETCH PRIMER
It states its good upto 220c.
product can be found in the UK if searched on the interweb.
regards
Number of posts : 500
Post  Adam Brown on Fri 22 Jun 2012, 8:48 am
Hi Brian
I think most Primers have a high degree of heat resistancy, especially etch. Obviously it depends on the individual products though
Adam Brown
Number of posts : 63
Post  Tim Watson on Sat 23 Jun 2012, 1:50 pm
You can always consider chemically blacking the brass.
Post  Tony King on Sat 23 Jun 2012, 4:41 pm
Hi Brian,
Plasticote do a high temp black paint for wood stoves, not to be confused with their black high temp paint!!........ It's sticky stuff until it's baked but will stick to non ferrous as well as ferrous metals............ it's worked on everything I've coated with it!!
High Temperature paint
Post  Steve Traill on Sat 23 Jun 2012, 6:35 pm
I'll second that, sprays nice from the can although it works out expensive at 8 a tin
Number of posts : 751
Post  bjwlancashire on Wed 27 Jun 2012, 1:46 pm
Thanks for all the replies/recommendations, I am going to try the etch primer I already have based on Adam's comments - fingers crossed. It will have to wait until after the house move now, 2 weeks this weekend and Blackbeard is not back on his wheels yet!!!
