tender inspection cover
Post  Dan on Fri 15 Jun 2012, 6:18 pm
Quick question - Can't make up my mind what to do with the tender inspection cover, paint all over or isoflex one one side, paint on the other? What have others done?
confused
Dan
Number of posts : 122
Re: tender inspection cover
Post  Robfishman on Fri 15 Jun 2012, 8:15 pm
Dan wrote:Quick question - Can't make up my mind what to do with the tender inspection cover, paint all over or isoflex one one side, paint on the other? What have others done?
confused
Ive painted one side and POR the other, will then make up a gasket to seal it.
Post  Kevster on Fri 15 Jun 2012, 8:30 pm
Thats what i will be doing too.
Post  Dan on Fri 15 Jun 2012, 9:16 pm
Sounds sensible. I might even try instant gasket and a layer of Vaseline. Never had to inspect my current tender.... Mind you it is brass!
Dan
Tender cover
Post  Steve Traill on Fri 15 Jun 2012, 11:25 pm
On my engine I just painted both sides of the cover and use a smear of grease to form a seal. It doesn't leak & neither has it gone rusty. When laying up the engine for the winter I drain it right down, sponge out the dregs and check the Isoflex to ensure there's no rust anywhere. I also check the filters on the pick up pipes to make sure they are clean. I replaced the brass bolts for stainless steel ones as brass doesn't age very well when in contact with water & I didn't want any heads shearing off.
Number of posts : 710
