Started Value Issue
Started Value Issue
Post  Brian M on Thu 07 Jun 2012, 9:25 pm
Hello All,
Having put the starting value together (Kit 27), I noticed an issue when connecting it to the cylinder. The holder for the ball bearing is much wider than its intended hole in the cylinder block. Therefore, do I make the hole in the cylinder block bigger, or do I reduce the length of the holder (as it is longer than the starter value cylinder).
Did anyone else have this issue and if so, how was it resolved?
Thanks in advanced.
Re: Started Value Issue
Post  highpressure on Thu 07 Jun 2012, 10:32 pm
There should have been a note in the insructions to drill out the hole in the block to 6mm instead of the 4mm it was drilled by STW. If I am remebering this wrong I'm sure someone will correct me. Its a very easy drill out just watch the components on the slide bar.
Post  Brian M on Fri 08 Jun 2012, 8:10 am
Cheers Kev
