Foden Kit 20/19 Contents
Post  Steam Traction World on Wed 10 Dec 2008, 5:34 pm
Hi Foden Builders,
Below is a list of items that will be despatched Thursday 11th December or Friday 12th December at the latest. An invoice totalling 360.25 will be included.
Flywheel Cap
2nd Shaft Supporting Bush
Chain Adjuster Block
Gear Change Gate 3 Pos
Gear Change Gate 2 Pos
Gear Selector Arm
Fast Gear Selector Arm
Gear Selector Lock
Water Pump
Water Pump Gland
Water Pump Ram
Water Pump Vent Pipe
Safety Valve Cover
Water Pump Gudgeon Pin
Gear Locking Pin (x2)
3 x 3 PTFE Gland Packing
Set of Replacement Eccentrics
The balance of the wood for the roof should be in on Tuesday 16th December which we can then pack and despatch by the end of the same week for a pre Christmas delivery. The roof is being sent as a self assembly kit and the package includes the relevant jigs to make the assembly reasonably straight forward. As we are sending the roof as a kit it has enabled us to reduce the price form the original price quoted of 587.50 to 402.50.
Dean & Steve
Number of posts : 902
Re: Foden Kit 20/19 Contents
Post  Steam Traction World on Fri 12 Dec 2008, 6:36 pm
Kit 20/19 was despatched today for a Monday delivery. Invoices for both this kit and the roof kit were enclosed.
Hopefully this edges you a little closer to completion.
Dean & Steve
