Stephenson link travels sideways when crank is turned
Post  Brian M on Sun 22 Apr 2012, 8:38 am
Morning All,
An afternoon of fixing the eccentrics to the slide valve motions work (Kit 21) has led to a Saturday evening of frustration. I have aligned the crank in the housing (all runs smooth) but after about six turns of the crank, the Stephenson link travels in its housing (to the right if the crank rotated clockwise), which means the link rubs against the side. This travel, therefore, stops the crank from turning.
Has anybody else had this problem, and if so, how is it resolved.
Thanks,
Re: Stephenson link travels sideways when crank is turned
Post  Tony King on Sun 22 Apr 2012, 9:45 am
Difficult to recomend a remedy without actually seeing set up, however there should be no sideways forces on the Stevenson link, which suggests to me that your eccentrics are not correctly lined up to the link from the crank shaft.
I don't know of anyone who has encounted this problem, cirtainly mine went together with no problems at all.
Hope this helps, if it don't, say so & I'm sure a solution can be found!!
