Adam's Wheel
Adam's Wheel
Post  MrStationHouse on Sat 14 Apr 2012, 5:57 pm
I have just picked up my first rear wheel which was painted by Adam Meredith, some might think it is cheating, but what a paint Job!
I had some special rivets made with offset heads to allow the second red ring as the ones supplied extended over the edge of the T Ring.
This is the front wheel which was finished some months ago.
Best wishes
Number of posts : 313
Re: Adam's Wheel
Post  Robfishman on Sat 14 Apr 2012, 6:51 pm
Stunning, a really great job. I'm waiting for the final rear wheel before I top coat and line mine. Have started the front end and putting a single line along the centre of each of the leaf springs is quite a challenge.
It looks like the wheel has been varnished, or is it just the reflection of the light on the paint work?
Re: Adam's Wheel
Post  MrStationHouse on Sat 14 Apr 2012, 7:39 pm
You are quite right he has varnished it. It does make all the difference to the final finish, as to longevity we will have to see.
A line on each of the springs, that is a challenge
Re: Adam's Wheel
Post  Flasback on Thu 07 Jun 2012, 7:32 am
Hi Simon,
I am having a good look through the photo section as I have not done it for a while, hence my posts all over the forum today, I do like your wheels. I had mine done by a paint shop and what a great job they did; I could not have done the finish they did. The first thing people do is look at your wheels and then the rest of the engine, so having good wheels is important in my view. The problem I found is that when you paint you will compare your finish to the the wheels and end up rubbing down to do it again.
Maybe what we should do is upload a single picture to a STW gallery page so we can have a good look at all the engines being done. It's a great way to see what is happening and to get great ideas on colours etc (most of my ideas on the engine were not my own Embarassed).
Flasback
Number of posts : 186
Re: Adam's Wheel
Post  MrStationHouse on Thu 07 Jun 2012, 1:11 pm
What a good idea.
Re: Adam's Wheel
Post  lynnr on Thu 07 Jun 2012, 2:43 pm
Flasback wrote:Hi Simon,
Photo threads already do that?
Number of posts : 2915
Re: Adam's Wheel
Post  Flasback on Thu 07 Jun 2012, 4:02 pm
okay, lets set up a thread then where you can say put two pictures of your engine so it acts like a shop window of engines done so far, any more than two and you might as well go to your own photo threads which is not the purpose of the new thread. I will have to ask Brian to put my engine up but I am sure the rest of the STW community would not mind doing it as the engines are a credit to all.
I don't think we can nick the gallery section not unless Craig lets us.
Dwain
Flasback
Re: Adam's Wheel
Post  craig@STW on Thu 07 Jun 2012, 5:45 pm
didn't know we had a gallery section !?!?!? Shocked
the photo thread is a good idea, we used to do it on the mini forum. you post up a couple of good pics and keep the words to a minimum. as your model progresses you can change the pics to your latest ones. it gives a nice quick reference photo topic that's a lot better to scan through.
someone start one up in the "owners photos" section an i will "pin" it to the top of the forum (means it always stays at the top of the list Wink )
Number of posts : 1256
Re: Adam's Wheel
