Regulator and Safety Valves
Post  lynnr on Thu 05 Apr 2012, 9:28 am
HI STW
Since the latest kit tells us to install the safety valves. I been thinking. Would it be wiser to hold off until the regulator handle assembly arrives as currently the regulator block is not adjusted to the correct length in the cylinder.
Number of posts : 2962
Re: Regulator and Safety Valves
Post  highpressure on Thu 05 Apr 2012, 12:56 pm
Seeing we don't have any bolts to hold it down and it's unlikely to take more than 2 minutes to attach it I would say hold on. Besides depending on how you carry out the cold test you may want to get to the regulator and/or try to seal off the safeties ( or remove and replace with a blanking plate ) to hold the pressure in. As I see it there are two ways to stop the safeties from ejecting the cold test water, either a clamp of some description on the outside to keep the poppet valves shut or a blanking plate under or to completely replace the unit. I would go for the second option myself.
