Hole in whistle
Hole in whistle
Post  chop on Wed 04 Apr 2012, 7:22 pm
So what size hole do we have to drill in the whistle base And where ?.
chop
chop
Number of posts : 77
Re: Hole in whistle
Post  lynnr on Thu 05 Apr 2012, 8:45 am
About 3mm will do very well. Fits but not too tight. Remember to limit your plunge as the brass is very soft.
Number of posts : 3022
Re: Hole in whistle
Post  craig@STW on Thu 05 Apr 2012, 10:39 am
lynn is right. the 3mm angled hole that comes up from the base of the body should continue through into the part that has been screwed into the side of the body.
at the moment the steam is blocked and will not operate the whistle. drill this hole through and you will create the steam passage so the assembled whistle can act like a tap and work as it should.
Re: Hole in whistle
Post  chop on Thu 05 Apr 2012, 2:26 pm
Thanks didn't have the kit when i posted. Now i see what needs doing . Very Happy
chop
chop
Re: Hole in whistle
