kit26 9/16 x 26 lock nuts ????
Post  craig@STW on Tue 03 Jan 2012, 8:27 am
we have had reports from a couple of people that the 9/16 x 26 lock nuts (SP59008) were missing from kit 26 !!!
yes, they are not on the packing list BUT mike assures me they were in the kit and we have a sheet of "part number stickers" with half of them missing.
can you all please check to see if you have them
craig Cool
Number of posts : 1296
Re: kit26 9/16 x 26 lock nuts ????
Post  lynnr on Tue 03 Jan 2012, 8:31 am
craig@STW wrote:we have had reports from a couple of people that the 9/16 x 26 lock nuts (SP59008) were missing from kit 26 !!!
craig Cool
Hi Craig. No unidentified packages here. All other items in box have been used and or accountied for use. Nuts are definately missing as stated on the 24th.
Number of posts : 2956
Post  craig@STW on Tue 03 Jan 2012, 12:29 pm
yep OK, i think we have worked it out. you were sent 1 lock nut and you should have been sent 3 ???
we will sort this out and send you some more Cool
Lock nuts!
Post  Tony King on Tue 03 Jan 2012, 4:08 pm
Hi Craig,
Just be aware that the lock nut which we did recieve is NOT the same size as the ones we need to lock up the sight glass bodies to the boiler connections....... I know you probably knew that, but just checking!!
The Brass Monkeys
Post  lynnr on Tue 03 Jan 2012, 4:15 pm
I actually think it is the Brass Monkey that stole the brass nuts as it has been cold enough up here to freeze the balls off a brass monkey.
Where's me nuts??
Post  highpressure on Tue 03 Jan 2012, 5:23 pm
Hi Craig,
Just to confirm I dont have the lock nuts either. I take it they go on the thread that attaches the water gauge to the engine to lock up the unit on the boiler and top connector. I seem to have the nuts that hold the glass in the fittings.
Also can you confirm the threads of the water taps on the tender as I need to clean them out with a tap to get the fittings in. Also the threads for the blowdown valve ( 1/2" BSP? ) and the water tap on the bowser ( 3/4" BSP? ) as again I need to clean the threads out to get the fittings in.
Thanks Kev.
Lock nuts
Post  Steve Traill on Tue 03 Jan 2012, 7:55 pm
Have checked my kit 26, I'm not at the stage of using it yet, and in the globe valve bag I have one 9.16 x 26 lock nut. Should there be more than one?
Number of posts : 720
Post  craig@STW on Tue 03 Jan 2012, 10:25 pm
one for the globe valve and two for the water gauge.
don't worry, it'll be sorted Cool
Sorted
Post  Steve Traill on Fri 06 Jan 2012, 9:29 pm
Just received the two extra lock nuts, thanks Craig, problem sorted!
Excellent service cheers cheers cheers
