Kit 17 Belly Tank
Kit 17 Belly Tank
Post  Kevster on Sat 24 Dec 2011, 6:30 pm
Just finished putting in the last of the riv bolts on my belly tank
Have to say what a great job STW made of this kit, I was a bit worried before I started about getting all those holes to line up
but it went together extremely well and was a pleasure to put together.
Instead of a sash cramp I pull it all into position with a small ratchet strap.
only sore point is my fingers but all in now and looking good so the pain was worth it.
Merry Christmas
Re: Kit 17 Belly Tank
Post  lynnr on Sat 24 Dec 2011, 6:32 pm
Hi Kev
Do not lock the balance pipe elbow into the tank as you will need to remove it to allow the pipework to fit. Took me a good 45 mins to remove the nut as the isoflex had a very very good grip on it.
Number of posts : 2969
Post  Kevster on Sat 24 Dec 2011, 6:35 pm
Ok Lynn,
I was thinking about not fitting it until later in case it needed to move, I definately will leave it off now.
Post  Brian M on Thu 12 Jan 2012, 6:59 pm
Is it not possible to pivot the belly tank whilst attaching the pipework? Seems a shame to break a perfectly good water tight seal.
I was going to nip to B&Q and buy a piece of 22mm pipe and cut to size (as I am about to attach the cladding and belly tank). Therefore, how long is the balance pipe from the tender to the belly tank.
All the best,
Post  Rickster on Thu 12 Jan 2012, 7:47 pm
Hi Brian,
You do not need to remove the elbow to fit the balance pipe. If you look at my thread in the photo section I've tried to describe how I fitted it without removal. It's not difficult to do really.
Post  Brian M on Thu 12 Jan 2012, 9:52 pm
Cheers Rick, I have read the thread and will emulate. By the way nice looking engine (particularly like the smoke) Very Happy
All the best,
Post  Rickster on Thu 12 Jan 2012, 10:01 pm
Just a bit of old newspaper in the firebox for effect, - seemed like a good idea at the time!
Post  lynnr on Fri 27 Jan 2012, 9:41 am
Hi Rck
Any pictures of your belly tank?
Post  Rickster on Fri 27 Jan 2012, 9:50 am
I can go and take some - anything in particular ? or else in my thread there are photos way back when it was all painted
Post  lynnr on Fri 27 Jan 2012, 10:49 am
Rickster wrote:I can go and take some - anything in particular ? or else in my thread there are photos way back when it was all painted
lol Ah so there is. never mind me going daft.
Post  bjwlancashire on Fri 27 Jan 2012, 1:26 pm
Any pictures of your belly tank too? I am just about finished with mine, end panels will be on this weekend.
I build mine slightly different to the instructions and did some preparatory work that meant I did not need any type of clamps to pull it together. I will post an alternative thread about it for those builders behind us to look at. You can never have to many options!!
Post  Kevster on Fri 27 Jan 2012, 4:45 pm
I am painting it at the moment will take a few pics
Post  Kevster on Fri 27 Jan 2012, 7:15 pm
here are a few photos of my belly tank in the process of painting and my contraption for
holding it
Post  bjwlancashire on Sat 28 Jan 2012, 12:27 am
Interesting contraption, what was it before it was a painting stand? Something off an old drawing board maybe??
Post  Kevster on Sat 28 Jan 2012, 7:40 am
Its made of junk !
base is an old piece of school sports equipment
length of round steel
large lump of wood
some studding
tube is a chrome leg cut down
and some builders fixing strap
I used it to hold the tender when painting that too,I dont have room for an engine stand so had to come up with something else.
