Rear Axle fitting
Rear Axle fitting
Post  Kevster on Sat 03 Dec 2011, 4:48 pm
Just spent the afternoon wrestling with my rear axle.
A tight fit is not the word, I didnt think it would be going in at first but after lots of twisting and turning it went in.
I rubbed the axle with wet and dry, turned up a cast iron "piston" the size of the axle.
used that as a lapping tool in a pistol drill with some fine valve grinding paste to open out the bearings a bit ,cleaned all that off,switched to time saver compound.
All the time testing the axle,done one side then the other then used the axle with the timesaver lapping compound to finish the job off.
Reading some off the post on fitting axles some seem to go in with just a tickle, mine definately needed a lot more than tickling.
Thats a fair lump off metal to swing about so im having a rest for a bit now Smile
Axil and keep fit
Post  lynnr on Sun 04 Dec 2011, 8:57 am
Hi Kev
I worked it out I lifted the axil so often by the end of the day of fitting I had lifted over 1.5tons.
Number of posts : 2915
Re: Rear Axle fitting
Post  Kevster on Sun 04 Dec 2011, 9:25 am
I can quite believe it, no need for gym membership with this build eh!
