Front belly tank bracket
Post  Kevster on Tue 29 Nov 2011, 8:43 pm
Hi everyone,
Got my belly tank kit ,got the modified tank to hornplate brackets too.
Do I need a modified front bracket or is the front bracket part number BS41713 the correct one and all I need?
Is it the boiler bracket that bolts to the front bracket the bracket that is modified ?
Re: Front belly tank bracket
Post  lynnr on Wed 30 Nov 2011, 8:14 am
Hi Kev
You should get 2 off angle irons for the rear. These having 2 rows for bolts, one row being dummy and not sure when a front boiler to belly tank "U" bracket with 2 slots at the boiler interface instead of a pair of normal drilled holes on each leg.
Number of posts : 2963
Post  Kevster on Wed 30 Nov 2011, 4:41 pm
Thanks Lynn,
I have the modified tank to hornplate brackets just wondered if the front bracket had been modified too.
